Thanks for the links and picts of your builds Brian of O and Biker Smurf. Of all the searches and reading I did I never saw these. I needed to go to 19 1/2 on the engine set back otherwise the rear driveshaft would have been a CV joint with flanges.
I layed in my steering shaft and it looks like my clearance is good. The closest point is to the frame rail not the manifold.
Pulled the tub back off last night to start scoping out what I need for fuel lines. 72 FJ40 Chevota Build
While the tubs off I'll lift everything another 1 3/8 - 1 1/2.
For those of you with Firestein motor mounts, do any of you have a Saginaw P/S conversion kit? Will the steering shaft clear the motor mounts?
