Thanks guys I really appreciate the input!! About the VSS, I have done a lot of research on this, even bought a VSS from JTR and ended up returning it due to the requirement of a reluctor ring for my year which is NOT even available yet and is a custom machined unit that they are working on. I agree if you are running a automatic tranny a VSS may be required for accurate shifting and performance. My setup would also require a VSS buffer which is a another story, again this is all fine and good IF you are running an AT. I will remove the TBI and take a look at it, I think it could use a kit anyhow.. I should be getting this on the road in the next week or two and will update this post as to the results.. One other thing about the ECM, I have checked quite a few resources on chips and it seems that to get a chip burned to eliminate the AT tranny codes and VSS will cost me $170.00I think I will see how things go with the stock program and put the money into obtaining the equipment to program and modify my own chip, saving me lots of money and time in the long run..
Time to visit Moates.net for tuning tools. With an OB1 computer, its basically a check/uncheck the box deal for VSS, etc using Tuner Pro RT. You probley know this allready.
.. I am however still dealing with this SURGING at idle. I have checked for vacuum leaks: none, replaced the ignition module, took off the TBI: cleaned it and put new gaskets on, pulled the EGR valve: tested it, checked the ports for buildup, reinstalled with new gasket, changed the MAP sensor, Fuel pressure does not very from 12psi, the only change from the stock motor are the block hugger headers. Now here is the weird thing, when I pull the timing advance connector, it smooths out but the O2's go through the roof
, also when I pull off the vacuum control from the break booster it smooths out
