33's
Terrace, BC
hey fellas i got the chance to pick some unused 33x9.5 bf goodrich
all terrain... my truck is stock as i understand it i can just crank up the torsion bars in the front and put in some lift blocks in the rear and she'll sit over them okay? any advice!
33INCHTIRES
I'd do a Ubolt flip on the rear if you do blocks, or do some add-a-leaves. Alot of people don't like blocks, but I run a 1.5" on my rear. If you make the plates, you can get an oriellys ubolt/block combo for 40.00, and theyll warranty it when/if they break.
did you check the FAQ?
I put 33's on with just the torsion bars cranked up. I did have to beat on a pinch weld on the front so the tire didn't rub on it. I have since put a 3 inch body lift so easy fit now. I would also suggest changing your gears to 5.29s
What usually causes rubbing is the width of a tire, causing increased positive scrub radius, not height. With a 9.5, I would start by running it stock and seeing what happens.
Im sure most people offering their opinions on what to do to make 33's fit used 12.5's.
yeah that's what i was thinking about the rubbing. 12.5's would make a way bigger difference. but we'll see, i have to go to camp to work for a couple of weeks and when i get back the truck is getting a new front end and tires and other stuff. should be fun.
matt
im running 33x12.5 no rub but then again i do have a 2"bl that i made way before i got the tires
