3 speed trans rebuild
Nomad - www.wegonow.net
Forst off I used the search function.
I am doing a frame up resto on a 1969 FJ40. 98% stock incluidng the colum shift trans. I have the trans and transfer together and ready to install.
These buggers fell out..... I looked at the manual and online at spector....cant findem......
Help
Thanks in advance
PVCruiser said:
I'd be willing to give you a three speed...
Thanks! Everything is good on this one, just not sure how to get the dogs back in the thing......
perfect! Thanks again
Look at the schematic. There are two part number 6's. One on each side of the gear. They have openings. These openings should be 120 degrees offset.
The dogs, part #7 act as retaining clips. You should have three. The gear has a cut out every 120 degrees. Install the dogs with the two legs facing inward as the schematic shows.
Then install the snap rings, offset 120 degrees. The snap rings have a catch on either end. This catch should catch the dog....
Play with the gear, the dogs, and the rings... You should get the hang of it. Post up a pic of what you think is right, PM me and I can comment.
HTH
Here are teh dogs installed . I only found 2 in the trans.
I may take you up on that 3 speed trans you offered.... How much to ship to 54016??
Thanks Steve. I will shoot out on Saturday or Sunday.
fj40charles said:
What are you talking about Kemper? Have you changed sides now?
Nope, still an F guy....
Greg-
Make sure that the bolts that hold the tcase onto the transmission thread into that transmission you picked up....the thread pitch changed somwhere around 1971, and I cannot remember exactly what truck that trans was out of.....
Let me know if you need anything else.
-Steve
Poser said:
Greg-
-Steve
Thanks, I will. I managed to get the two short inner bolts in and I plan on ordering the remaining bolts from spector. The trans cleaned up very nice...
As i get further into this buildup I am sure I will have lots more questions..........
