3 Speed Gurus!
I have never seen the bearing cage hit the seal, is the spacer between the trans rear bearing and tcase input gear in there ? Honestly at this point a call to Georg at Cruiserbrothers would be the fastest way to solve problem.
Thanks for the vote of confidence John. :rolleyes:
Your seal was installed correctly. However, If you’re not careful installing the transmission to the T-Case, the seal spring comes off and get wound up in the rear transmission bearing. From the pictures, that’s what look like happened.
That seal is a bear sometimes.
@peesalot has 4 speed on the brain. No spacer on the 3 speed. As for the seal, did you apply lubrication when you assembled it?
I did, but I could see how the below could have happened.
The seal is torn and the spring was chewed up. I would have never guessed the spring could cause that much damage!
@65swb45 , what part number is your kit for the 4 speed tcase swap components? And isn't there a difference in low range on the 1975+ transfer cases vs the 3 speed cases?
