3 spd flange needed
SE Mo
Hey there, just wondering if someone might have an old 3 spd case d/shaft laying around? Just need an end, to add to my shaft for SM 420 swap. Thanks, Al
Specs are HERE
Al, if ya can't find an OEM cheap, Kurt at Cruiser Outfitters has them for $33.50. Cool thing about his are if you decide to change drive shafts or t-cases later you can clock and re-drill Kurt's...... Not that I've ever had to do that :bang:
I guess maybe I worded that wrong. I have the 3 spd flange on the f/output of the t/case ( '72 3 spd case ). I'm needing a ujoint/yoke assembly off the end of a d/shaft, to add to a longer slip mini d/shaft. I guess its the 64 x 56 mm bolt pattern, as its smaller than my '77 pattern. This is for a 420 swap, using Pin Heads writeup. Al
