I had a few questions. (I am actually buying the custom made lift which ben at slee had made. ) Sorry for so many questions but havent found the answers in my searches.
Actionjackson was gonna use a 3-link to correct for caster....how does a 3link correct caster?
The heim Joints are adjustable...is that the way the caster is corrected? and if not how do most people correct caster on a 3 link?
I will be using 6-8" lift springs. Stock location for lower control arms. Custom control arms that use the stock locations. What angle does the panhard need to sit at? it seems on a lot of 3-linked that the arm is level under full compression on that side. Also due to this it would seem better to keep the panhard tower on the axle fairly short and drop the bracket that attaches it to the truck? Please correct me if I'm wrong.
Additional question-do yall have to lengthen the stock rear driveshaft or is it fine with this much lift without slipping out?
I plan on using the adjustment sold by slee to lengthen my tie rods. and 14"-15" shocks. Extending brake lines. DC shaft.
