3 link conversion on lj73
Hellas
I'm thinking of go on 3 link conversion to my lj73 . Has anyone done it ? What do you think about it? Any opinions, ideas?
The rear of my kzj70 is 3 linked on a 2" lift, had a build thread but photofxxxit happened, will get some pics tomorrow if you want
Yes please ...i'm on a 2" trail master lift kit but no flexibility
I find with mine, the rear flexes really well just with a OME 2" lift and removed sway bar.
The front is more of an issue for me even with the sway bar removed. But I think I just need some longer springs. The front OME's I have are basically stock length but a higher spring rate. I had to add spacers to get the front up a bit more. I'd like to get longer and softer springs. I think that would help a lot. When funding allows I think I'll buy the Dobinson 60mm front springs.
This LJ has the right combination of springs/shocks in my opinion. This is not a 3-link setup, but you can see it is flexing well in both rear AND front. Here is the thread these pictures came from: Which locker should i give my LJ78
img_0119-jpg.734129
img_0120-jpg.734130
img_2821-jpg.734138
