I have an 1978 fj40 with a 2" spring lift and i was wondering if i could just unbolt the old body lift and put 3" body blocks and bolt them on. is that all i have 2 do or is there other things i need 2 do such as longer brake lines and wot happens to the steering. and since it will have 5" lift will that be enough to fit 37" wheels. thanks
Guys like treerootCO and alf are running 37s with SUA lift (last I read). I'm sure they are running 4" or bigger custom springs with extended shackles and lots of body trimming. Don't forget that gearing will probably become an issue.
Do some searches on the above MUD handles and study their posts.
SOA, 3 inch body and 38.5 's Here steering is abit of an issue .if stock .2 inch body is easier to work with using stock steering .i used a ross stuart's , advanced handling aproach one time with stock steering it worked only issue really was at the steering box .but you just unbolt it get longer bolts or studs and put a 3/4 inch spacer under the steering box .and lower the steering column a bit inside the cab .may need to drill new holes . it works .but not ideal . i don't think you will get 3 inch body and stock steering to line up without some mods . body lift is fairly straight forward .when you have saginaw installed . other than shifter issues .transfer case shifter needs looking at .shifter hole usually needs modifying .brake lines need stretching .some wiring needs to be adjusted . i think i posted this pick before
3/4 inch steering box spacer for 2 inch body lift.
