I know there have been lots of posts of Dual Batteries so this my be a bit redundant.
I wanted Dual deep cycle batteries for winching and camping and an extra battery for emergency start. The 2 Primary batteries are starting/Deep cycle from Costco. They were about $70 each. Although they are mot the best battery available tehy do repesent a good value. The Third Battery is a Odyssey PC680 Motorcycle Battery used only for Emergency Start.
The two Primary batteries are wired in parallel with a Kill switch to disconect them from the vehicle. The Odyssey is wired with a relay to provide a charge current when the Alternator is hot. It also has a Disconect switch that is left open until needed.
By wiring the batteries this way I can remove the two primary batteries from the alternator load and run off the odyssey. If happen to drain the 2 deep cycle batteries I have the option of disconecting them and charging them later at home rather than bruden the alternator with such a large load.
Is this set-up over kill? You bet! Will I be left stranded with a dead battery. No way!
