2WD Landcruiser???
Pensacola, FL
So, I fixed the head gasket along with all the other little issues on the engine. Good news is it runs and shifts great. Bad news is, i only have power to the rear wheels and I can't get the CDL light to go out. The front drive shaft is spinning. My thought is the previous owner ran into issues with the birfs and somehow either removed or one is broken and they manually locked CDL so power wouldn't be lost to the free spinning front. I realize I won't know for sure until I dig into the front. Anyone have any advice or seen this before. I love this truck. At this point I feel like I am just saving a cool vehicle from the grave...
Congrats on wrapping up the head gasket ! Sounds like youre fetting closer to a healthy cruiser. At least she drives to the parts store now.
Hopefully just a stripped drive flange
Is there a cdl button or substitute ?
Or they may have put in low to lock ctr diff, pulled diff actuator fuse, and then put back in high
Is the abs light on too ?
Thanks, it does get to the parts store nicely now! I don't believe a 91 had ABS unless I'm mistaken... no light on. It does have a cdl button. I checked the fuse under the dash and it appears to be fine. I think I read there is a second one.(Not sure where it is) Excuse my ignorance on what a drive flange is. Is it on the front driveshaft input or birfs?
Common enough. Plus easy to check and relatively inexpensive to remedy.
Jack up the front end and spin a wheel, what happens?
Don't even need to do that, unlock the center, remove the drive plate dust caps, have a helper attempt to drive while watching the birf stubs. If one is stripped, the birf end will spin without turning the drive plate.
I can't unlock to CDL. I read that there are two fuses for a 91-92 but I can only find one under the dash. Is the other a relay? Can someone help me locate? I'm sure that it is locked on purpose by the previous owner.
The "GAUGE" fuse is also associated with the CDL circuit, but if that were bad, you'd have a lot of problems.
Maybe look to see if the CDL actuator wiring was disconnected, or the CDL relay was disconnected (left kick panel).
Ok, I did discover that the issue was a stripped drive flange. Now I still cannot unlock the CDL. I looked at the fuse and its still good. I don't see anything unplugged under the truck. I measured voltage across the fuse terminals and it doesn't read anything. I am at a loss. I need to get the CDL unlocked before installing the drive flange. Please help.
When the CDL is activated, does the relay in the passenger kick panel click, the actuator motor run? Did you review the thread linked above?
I took it off and didn't see a relay. What exactly does it look like?
Read the links or search. The CDL button goes to a relay and there are 2 ball type switches on the trans, 1 for indicator, 1 for the switch. Youcan remove both and test them..... assuming the relay is good and to them wiring is good.
Not sure about your '91, but on my '97 it's behind the DRIVER (left) kick panel. It's a black box labeled "transmission relay", but it's actually the CDL control relay.
It looks like this:
