Posted this in the 60 section with no luck. Thought it might be more in line with this group
Last winter had a toybox put in my 60 with the stock 4spd. I ran it to LSCR without any problems. In June I went to Razorback Ramble and it started acting up. When i use the tranny as a engine brake to go down steep hills, second gear would start to go away. At first it would start jumping out of gear and then it would get to where I could not get it in gear at all. It was like 2nd had moved away from the shifter. I could get back to camp and and take it out on a road and drive it normal and 2nd would slowly come back. The only time it goes away is on steep descents and it comes back with normal forward torque from driving on the road.
When I got home and took off the skid plate, I found that the transmission mount bolt had come loose. I set it again and used it in some easy situations and it seemed fine. Last weekend at FlatNasty w TAC it started acting up again. Not as bad as RR but it was still popping out of gear on hill descents unless I kept my hand on it. I will check the bolt this weekend to see if its come loose again.
There are no other signs of problem. 1st, 3rd, 4th, and reverse are fine and there is no grinding or sliping problems. I dont understand the transmission enought to know what could be causing this. I do know that LSCR had no hills as long as what the other two places had so It may have started at RR or it may just not have been put in a situation that caused it in Texas. It may not be a toybox problem. I just dont know.
Thought, answers,
P.S. I already have someone that has suggested I go back to stock and give the TOYBOX to them, so you dont need to suggest that option
Thought, answers,
