Last year I had a few problems with my cooling, truck would randomly overheat, so I decided to do a few things to improve it.
My prado has 2lte engine, and I have done a few things to keep it cool.
10 blade fan off a newer hilux - direct fit
Fan clutch pulley off a 1KZte, it is 30% smaller in side, so you fan clutch is spinning faster, and it provides more coolant flow.
For this, you will need pulley from 1KZ, it consists of two parts, you have to drill out 2 spot welds that hod it in place and then use 4 washers as a spacer to prevent it from rubbing against timing belt cover.
82C thermostat
