2h engine issues
Sydney
Okay so I just did an oil filter, fuel filter and oil change. The ol girl was working perfectly before hand, now she doesn't crank over properly, it's almost like it's choking, I've removed glow plugs and cranked it to see if it over flowed but no oil came out. I have no Idea what I've done wrong or how to fix it. Any suggestions please!?
Remove valve cover and crank to see if you are getting oil to the rocker arm. If so oil is good. If you have an edic it is looking for a oil pressure signal from the oil pressure sender. Check to see that wire is connected. Curious, what oil did you use and how much?
you might have air in your fuel lines after fuel filter change. Did you purge air out of the injector lines?
Did it crank fast with the glowplugs removed? Was it bled properly after you changed the filter
