2fe cooling system question
arkansas
I have a 79' fj40 with a 2fe (3fe/2f components) that I have just now breathed life into. It runs extremely strong compared to the 2f but I'm having a cooling problem.
After several test drives, I've found that the coolant return (top) portion of the radiator reads about 235-240ish, and the coolant out(bottom) is reading about 180-190ish using an infrared thermometer. I'm just now getting everything finished up on the install and this is my newest/current problem. I should note that I have not got the exhaust installed yet, I will get that done on tuesday. I know that it should be running hotter without the exhaust, but that seems quite high. Do you guys think that the stock 4 row radiator is not enough for the increase in hp? I can replace it with a 5 row, but that's a lot of coin if I don't need it. I replaced the thermostat and that was not the issue.
Any help would be appreciated.
KC Hargis
I would think the stock radiator would be sufficient. In my 3FE'd FJ60 the stock FJ60 radiator works quite well. Perhaps the cooling problem lies elsewhere, loose belt maybe. Is the thermometer accurate? Just tossing out some ideas here.
Isn't the 3FE a smaller engine? If that is the case I don't see why the stock radiator wouldn't work. A lot of guys cool 350s with a stock FJ40 radiator.:confused: You have shroud? Radiator boiled out or rodded? I would look for some common cooling problem before shelling out for a bigger radiator.
JMO
Ed
EDIT: I'm sorry, but are you saying the water entering the radiator is cooler than what comes out??? That does not make sense. I may have misunderstood your terms...input/output.
Ed...again
I have a puller fan that's rated at 3300 cfms. Hot boil over like symptoms after parking. The top, what I'm referring to as coolant return to the radiator is the hot one (240 f). Well hell, I guess they are both hot because my bottom one is running at about 190 after about 10 miles highway speed, up and down moderate hills.
It can idle for 30 minutes or so (that's about the max it's idled since build) and the top will run a consistant 190 f.
I'm using an infrared thermometer that is pretty accurate.
I would say that the hp increase was quite significant maybe from the stock 135 to up to 170ish, just guessing. I just thought that maybe since it is producing such additional hp that maybe that is helping to contribute to the heating problem. That and the fact that there is no exhaust as of yet.
