2F starting issue
Hilton Head, South Carolina
quite suddenly, like over the course of 2 days, my 79 with rebuilt and desmoged 2f with stock carb went from requiring about 8 pedal pumps to start cold in the morning and only pedal to the floor when starting warm to requiring like 20 rapid pedal pumps to start and like 12 very rapid pedal pumps to start most times when cold. Yes, that was one sentence. Any thoughts? Changed plugs and fuel filter, no change. It runs fine once started. I’m thinking it’s time for a carb rebuild? Been about 8!years
I had to pump mine like 40 times yesterday to get it started.
It used to be just 10 times.
About -12C or 15F.
I'm thinking I need to do something.
Is your Choke working? Just sounds like you are enriching the air/fuel mixture via pedal pumps.
The choke seems to be operating..., I use it on cold starts (or it’s required for cold starts). I mean this happens with a warm engine on a warm day... like every start. Strike that... on warm starts I still first try thenwarm engine starting procedure of pedal to the floor and no choke. It has, on occasion caught but if not, its pump-o-ramma. I’ll check the sight glass next warm start to see if there’s fuel in there. Even after a crap load of pedal pumps, when it starts there’s no cloud of smoke or anything... it acts completely normal.
You might check the sight glass before you cold start too.
This is how I understand the fuel system working (someone correct me if I’m mistaken): When you pump the gas pedal you are using fuel from the fuel bowl. If the bowl is empty and your pumping, well then you really arn’t pumping fuel at all. If that is the case, then you are waiting for fuel to be pumped from the fuel pump into the bowl. The mechanical fuel pump is driven as the engine is running which is only running by way of the starter cranking.
I’m no expert, but I am learning about this system. If it were mine, I would check the sight glass first. If it is empty of fuel, then I would prime the carb and attempt to start, and see how that works.
My 2F was loosing fuel in the sight glass if it sat for multiple days. I had a fuel leak/vacuum leak at the carb base. Once that was fixed, my carb has held fuel for multiple days between starts.
