2F sputters and misses after warm
Georgia
Hey All,
My engine has began to sputter and miss after the engine is warm. After the engine runs for 15 to 20 minutes is when the trouble begins. I have changed the coil with new Toyota part and took the igniter apart and reapplied heat sink grease. Everything looked good. ???
See video:
Any advice would be great.
Thanks so much!
Great looking truck. How about your fuel filter??
Hook up a vacuum gauge to the engine. Betcha there’s a vacuum leak (sounds like it).
One source could be the EGR valve not sealing tight (if you still have it).
The first thing I would check/replace.
Does it idle any better if you pull out the choke half-way or so? If so, then suspect either the fuel cut solenoid on the carb is bad, or the "emissions computer" that controls it.
The air cleaner has a couple of vents uncapped.
