2f running rough
I have 76 2f running rough . What could be possible problems. It has an oem distributor that does not have contact points/condenser and msd ignition box . I have changed the plugs and wires.
Stock Aisan Carb?
Rough idle?
Can you post vacuum readings?
Checked all vac hoses? Desmogged?
Have you plugged brake booster line to rule out a leaky booster?
How’s initial acceleration? If sputtering during accceleration, does it ever smooth out or just buck and sputter constantly?
Does it run better with choke?
Have you checked that the choke plate isn’t stuck shut?
FYI According to coolermans “dizzy faq” page, 75-76 are vac retard dizzy’s. Late 76 is a vac advancer.
If it ran fine and this has just started check for cracked intake manifold and vacuum leaks 1st.
