2F or SBC?
so the verdict is to rebuild the F or swap for a 2F.... someone must have info on where to get a good price on a rebuild kit.. I am in the process of looking for a F rebuild kit, or getting a 2F and rebuilding it. Pac lift no longer sells parts for the engines, and other places are crazy priced... start a thread on rebuild kits?? and the best place to purchase them???
I bought a used 2F from someone on this board for $300 with all accessories attached. I spent about $500 on rings, bearings, gaskets ect. to freshen it up. I got a buddy to grind .010 off the crank, do a valve job, and power hone the block (can't beat free machine work, should have cost around $300 I think). I kept my F distributer because it was upgraded to pertronix before I bought it. Does make a little more power than the old F, but not by that much. Of course the F was running unusually strong the day it exploded. . . If I had more money then I would have bored it a bit, but the only pistons I could find were going to be around $700 I think. I couldn't afford it then. All in all I am happy with my decision. I may go to a SBC eventually, but mostly just for the wieght savings.
Again...
2F for DD
350 for TR or as a DD if you don't mind gas costs or polluting more. Personally I feel like a dick for wasting so much fuel just to haul my dumbass around town mostly. But on the trail it kicks arse.
350s are pretty cheap to fix or mod up. Plus everyone's response is usually like "whoa dude you've got a 350 under there :eek: ". So the cool factor increases as well. ;)
Have recently been reviewing these options for my 75 w/2F(compression@100,110,110,110,110,110). Napa complete master overhaul kit=1125.71. Disasembly,hot tanked,all machine work(crank ground,cyl.bored,head shaved,valve seats replacd,etc.etc.)then reasembly was $1900.00. I,m never going to pull a fifth wheel or horse trailors so all that unusable power of V-8 wasn't necessary for me.This 2F has all the torque and power i've needed it to muster for off roading. On pavement i'm never in that be of a hurry as there isn't alot of fast acceleration for passing.So i rarely pass anyone.Reasle seems much higher with original 6. My biggest complaint is MPG.It sucks. Good luck
I decided to go with a 350 since I came across a good deal on a complete truck that I was able to drive for awhile to see how it would run....
Haven't totaled everything up yet, I should be right around 2k or so with everything to do the swap. Getting the truck for cheap helped me justify spending more money on some other parts like guages and a new radiator.
It's nice not having to hunt for accessories too.:D
Small block all the way!!!!
I don't think installing a v8 hurts resale unless you're looking to sell it to a purist.
There are many, like myself, that would rather buy a 40 with a nice v8 conversion.
I saw a nice 40 on ebay some time ago that sold for 17K.
HawkDriver said:
Again...
2F for DD
i'm far from a purist, but personally i'd reverse those two statements (depending on the type of wheeling you do). my experience is the SBC's develop their torque higher in the rev range, where a 2f will lug like a diesel all day in low 1st.
on the freeway a 350 chev'll cruise more relaxed tho
Did my conversion back in the 80s and have never looked back. As mentioned above check out the smog laws before making a decesion. I have a 73 in Ca and it doesn't need smog.
The V8 rumble makes me smile every time I get behind the wheel :D
I daily drove a FJ60 for better than 10 years with the stock 2F, the inline 6 is an amazingly reliable piece.
To each his own, the 2F bottom end grunt is impressive but a V8 at highway speeds without re-gearing has it's advantages too.
