2f into a 74
What he said..
It's a thing of beauty:
:cool:
Just make sure you get the later model ignition with the 2F and include the ignitor, also the early flange on the exhaust manifold may not be the same as the later engine so you may need to swap manifolds, also the later fans are larger on the 2f so you may need a new fan shroud from a later 40, if your using a hedder not a problem with the manifold, Larry
