2f head installation question
:confused: I am getting ready to install the head on my 2f engine rebuild and need help regarding the pins that allign the head, block and gasket. I have searched the forum and read what I can find on the topic. It seems there are different names for the part (dowels, pins, ring pins, allignment guides) which adds to the confusion. I checked with the Toyota dealer and ordered what the are calling ring pins and they say that two are required. After examining the cylinder head and block surfaces I can only find one possible location for the pin which is the head bolt hole closest to the driver, left rear corner. Is something wrong? Do some 2f's just use one? Thanks for reading my question and hopefully clearing up my confusion.:eek:
My '77 2F had two on opposite corners. The only problem I have heard of is if you have the block decked or the head shaved to the point where the "pins", "dowels" or whatever they are called keep the head from seating and crushing the headgasket properly.
GL
Ed
There's two at diagonally opposite corners.
Mark...
The only pic I have is of the right rear of the block, so the other one should be at the left front. I think they all have two, otherwise......well, you know:)
HTH
Ed
Thanks for the picture and the thread link. I found that both pin ring holes were on the left side of my block, one on the back left corner and the other on the front left. When I removed the head there were no pins being used at all. It looks like somebody tried to fill the front hole on a previous repair. I had the block and head hot tanked and surfaced and what ever has been put in the pin recess didn't come out. I have been picking at it for over an hour and it dosen't want to completely come out. If I am unable to get the recess cleaned out enough to put a pin back in the hole would it be ok to have just the one pin? Should I go to the trouble of taking the block and head to the machinist to have him run an endmill into the recess? Thanks for the help!
