2F head 61202
Yucaipa, Ca
Hi guys, 9 yrs ago I bought my 76 FJ40 and use it daily. After yrs of tweaking, adjustments, and learning from many of you, it runs great. However, the method of oiling the rocker assembly is not internal. There is a metal tube attached to the passenger exterior side of the head between cylinders 4&5 that travels down and connected to the external oil cooler. With the valve cover off, you can easily see a casted passageway from where the tube is attached to the head going directly to the #3 rocker arm support tower. I had IH8MUD friend, Robfj40, check it out and confirmed that oil is definitely pumping up thru the tower and providing lubrication to all the rockers. Based on the casting number of the head (61020) it appears to be from Canada (at least that’s what I read). Is this something unusual, wrong or okay?
The more probable scenario is that a head gasket was changed at some point, the new gasket was installed backwards, and the internal passageway was inadvertently blocked off.
When said installer was not able to discover the true source of the problem they developed the alternative routing system you see.
The less probable alternative is that an F engine camshaft with a second journal oiler was installed in a 2F which uses a third journal oiler for the rocker assembly.
Very interesting, but what about the casting passage way on top of the head where the oil tube is connected that extends to the tower? I have not seen this on other heads. In fact, it looks like there is a factory casted threaded journal in the head where the tube connects.
You have not searched far enough. That is the horizontal section of the factory oiling passageway. ALL the 2Fs have one.
That passageway had to be ensured clear, so an access port was designed. There are many many threads about the plug that normally covers this access leaking or blowing out.
The good news is...yours will never do that!
:cheers:
www.marksoffroad.net
Wow, I now understand. Thanks. Do you recommend me removing the head and correctly installing a new gasket or if it’s working leave it alone?
Insufficient data to answer. You’d have to post pics of your setup. If it’s a Rube Goldberg :hillbilly: I’d say pull it. But if it’s a credible effort, I’d leave it be until something else needs to be done.
Mark, am I safe to assume that the oil galley plug typically blows out due to oil pressure? If so, would that mean that the PO, thinking there was no oil now feeding the rockers, then installed the external tube? That being said, if I inserted a plug, would the rockers start getting lubricated up thru the correct passageway?
In the 1st photo the oil tube is attached to a “t” block as I’m using both a stock oil pressure gauge and a number gauge. The 2nd pic shows the line to the head.
I’m guessing I should take it off and get it right....
The thing is, you don’t know if it’s the head gasket or the camshaft at this point, and your truck DOES run.
What concerns me most about your setup is how far it sticks out from the oil cooler. Lots of leverage there. If you had a metal T that screwed directly into the cooler, in the middle fitting, with the upper fitting servicing the oil delivery, and the lower for the sender, it would be a tighter setup.
