I will soon start an engine rebuild on a 1979 2F. The machine shop I'm using has a parts guy, and they quoted me $1,000 for his kit, which doesn't include an oil pump, iffy on main bearings, and only has 0.30mm O/S pistons. I can't remember if that includes timing set or not. I asked the machine guys what that was buying me in terms of brands and they said that if I'm brand conscious I could put together the parts... so I assume the parts are ITM or whatever the parts guy can get the highest margins on.
The engine rebuild won't be cheap - about $2700 of labor. I want to do this right the first time. I've been digging through a lot of old forums about rebuilds and kits and so forth, but still had some questions:
1) Looks like I can get many of these parts OEM, minus pistons and cam bearings. Are there parts I should definitely think about getting OEM? I am definitely planning on Aisin oil pump (unless there's compelling reason to spend 3x as much on Toyota pump? I thought Aisin was the OEM?). On the other hand, any parts that would be better to go aftermarket?
2) Anyone have experience with Spector (SOR) pistons or rings? The engine isn't apart yet but I'm assuming for now that I'll have a 0.50mm (0.02") over bore. SOR has them at $45/piston, and a ring kit for $155.
3) Anyone have any experience with liftpartswarehouse.com? They are showing lifters (no pun intended) with OEM part number for $11 a piece, way lower than toyota parts deal at $28 a piece.
4) If I don't go OEM, I'd be looking at Federal Mogul pistons + rod bearings + cam bearings + lifters, hopefully Hastings rings, Mahle/Clevite main bearings, Melling freeze plugs, Fel-Pro gasket kit. Not sure where to get the timing set yet. The engine I'm buying will come with a ground cam. This would bring my cost to around $950 before timing set. Any thoughts on these brands? Anything I should try to avoid or try instead?
5) Probably dumb question, but does anyone know the part number for .5mm over Hastings rings or how to find them? I only see standard sized ones.
I also checked in about RPM Ron's kit, which is $1,070 shipped. That does include the timing kit, but all but the cam, cam bearings and freeze plugs are ITM. At that point I might as well just use my machine shop's guy.
