2F Engine re-assembly
Fort Worth, Texas
I took apart my 2F a while back to give it a good cleaning and I now have some time to finish and put it back together. My question is what are the perishable parts in this process? I know I need a complete new gasket set for the block, head, timing cover, oil pan, etc., but are there any other parts that, barring obvious damage, can't be reused? Sorry if this is a broad question, but I'm trying to get a handle on the expense associated with putting the engine back together and the budget I need to expect.
Thanks in advance for the comments.
Scott
How many miles were on the engine when you disassembled it?
I'd certainly consider replacing bearings. Con-rod and maybe mains, did you remove cam bearings? Piston rings maybe. Rear main seal comes in the gasket kit? valve stem seals, heck, get a valve job while the head is off. Maybe freeze plugs.
Probably more I can't think of off the top of my head...
If your that deep into it I would consider putting a new oil pump in it as well.
An oil pump is not the first thing I would think of. They pretty much last forever. Wear is easily checked with a feeler gauge, and if wear IS excessive, just flip that gear around and it'll last another forever.
I don’t know about forever that’s a long time when I rebuilt my engine the oil pump was bad just something worth looking at.
Agreed it's something to check, which is easily done. when I rebuilt my 2F, the oil pump was one thing I did not buy new, 16 years later and still good pressure.
Also, an oil pump is not too terribly hard to replace later, unlike piston rings...
