2F Engine question - '76 FJ40
WA
Hi all,
Newbie land cruiser owner here. Picked up a '76 FJ40. It's in fairly rough shape, but fires right up and runs well.
The only "funky" thing is, when cruising and letting off the gas, or downshifting (engine braking), there is a loud grating sound, it really does not sound good at all. As soon as shift to a higher gear, or give it enough gas so that it's no longer braking by compression, the sound goes away.
Any suggestions on what could be causing this? Thanks for any advice that can be offered.
It could well be your rear diff bearings, inner or/and outer. Chasing down those at the moment in mine. Its a bit hard identifying where the noise is coming from when driving.. Mine sounds the same, Im going to get the whole diff rebuilt..
Gaz..
I believe you are right. I took it for another spin and the noise/grating is definitely coming from the rear. Probably needs a diff rebuild
