2F engine hoist points
Here is some of my 3F being lifted. The lifting points do not balance the engine properly and I had to shorten the chain to the rear eye to make it balance
I think its the t/case hanging off to one side that makes it rotate.
Someone must have removed your lifting eyes
Whoa Rosco! That 2F is different from mine. My engine hooks are exactly opposite and the power steering pump is on the carb side. I guess its the southern hemisphere. I bet the water goes down the drain the other way too.
I bent my rear hook lifting the engine out. Some of the hooks where a very weak design, so watch out. I modified mine so it will be much more sturdy.........
They made a strong one and a not so strong one.
Its kind of dumb they put a closed eye at the front and an open lug at the rear.
The closed EYE is stronger and should have gone at the rear.
I think mine are situated in the best position to take the weight of the t/case hanging off to one side
The engine is an aussie spec factory unsmogged 3F in my FJ73 when it was getting a diesel 1HZ
General consensus?
Open hook is weak (one in the rear). If it is used to lift the engine w/ tranny & t-case it may break.
Any good ideas on upgrades or alternative solutions?
The rear hook is the one that they make two version of. A weak one and a strong one.
PM 65swb45 for a strong one. Or check his web site at www.marksoffroad.net.
General consensus?
It held mine for several hours. Toyota recommend lifting the engine and gearbox as one so they must have tested it hundreds of times. They would look pretty stupid if everyone was dropping engines and trannies following their instructions.
You could also put on a back up sling of rope under the engine.
General consensus?
The strong one has an extra triangulation in it. I'm pretty sure they are both open hooks.
both are open.. And I have bent a ton of them without any failing...
I would not worry about it.
Damn they are both open,its the diesel that get the closed eyes;)
I concur, I just bent my front one pulling a 2F but it didn't break. Hammered it back in shape and will use it again (hopefully not anytime soon)....
Todd
Here is my rear engine lift hook, bent and twisted. I wasn't even pulling the transmission and transfer with the engine. Sawed the top off the old one and drilled a hole in it to accept the clevis pin.
