2F Break in oil
Montana
What are peoples thoughts on the ZDDP issue with breaking in a 2F. I am running Rotella in it right now, but am curious as to whether I would need to run a ZDDP additive. Like to have peoples thoughts on here.
:worms:
I'll add some tec... > here < is one of many found with the search function.
FWIW - What I used on my rebuilt 2F with all new OEM parts sourced from Beno...500 miles of this stuff:
Then was told to run the Valvoline 20W50 VR1 by the engine builder.....so that is what I use. Over a year later on the build and about 1,500 miles on the VR1 oil, it still has the golden color when I check the dipstick.
Proper break-in oil with high level of zddp is critical. My engine builder (MAF), recommended an additive that is no longer available, but there are plenty of quality break-in oils. I changed it at 100 miles. 300 miles and 500 miles. I should have done the 1st change sooner.
I will switch over to the VR1 then. I used to run that in my BMW's. Unless I can find the additive locally. Kind of limited as far as what we have available up here sometimes.
Lucas has a good quality break in additive for the older style engines - the local machinists around here building race engines swear by it . I was using Rislone concentrate , but seems they have changed the formula or something and I'm noticing a lot more noise out of my old Kohler engines than usual - so switching up to the Lucas . That VR1 oil is great , just not the price....
Sarge
The standard procedure used to be non-detergent 30W oil for the first 100-200 miles or a few hours, but there may be better options now such as break-in oil with very high levels of ZDDP for your (new?) camshaft to wear in. In any event, you want to vary the rpm and load for the first thousand miles or so, for the rings to seat well. I like to avoid very high rpm for a few thousand miles myself.
