2f 60 motor into fj45
Gardnerville, NV
Website
www.billetriflesystems.com
Cross posted from 40 forum.
Has anyone put a 2F from a 60 into a 40/45?
I’m having an interference issue with the lower radiator hose and the a/c belt. Then tensioner won’t go any higher to get it to clear over the hose.
Pretty sure the 2f is from an 83, the 45 I’m putting it in is an 82 from Colombia. Any thoughts/recommendations?
the a/c rads are wider than the non a/c 40 rad
Yes - cant say this issue came up - use the fj60 everything - my guess is the 40 lower metal tube got put on - or your shoved to far up into the thermostat hose maybe
Should be fairly simple straight forward swap
