250 Hybrid Battery Utility
N43.875, W121.455
Website
www.instagram.com
Does the hybrid battery in the 250 offer any type of overlanding utility or is it for high-voltage propulsion only?
20+ combined mpg on the truck, 2.4 KW (20 amps) of AC power, and 150 ft-lb of electric torque at idle.
Based on how our RX 350h behaves I anticipate the 250 will have very good low speed efficiency and driveability.
The 2.4KW is enough to use an induction cook element, make coffee, use an AC powered compressor and charge portable tools.
I should have been more specific, was focusing on electrical power for camping uses.
Thanks. So the answer is 'no'. That's unfortunate, especially considering the target audience (overlanders).
The answer may be "no" from the factory (I'm not sure anyone is certain right now), but surely the aftermarket can somehow make use of it. Modifying the rear inverter to be full time on (and not just ignition on) could be as simple as modifying a relay. Or maybe someone can come up with a software fix. Who knows, and who knows whether doing so would have serious consequences with regard to vehicle performance once it's turned back on.
20 amps vs 3 amps is a pretty big jump in capability and can power a lot of stuff for camping.
Maybe I read it wrong, but if it only works with the ignition on then it seems useless for camping and would still require some type of house battery solution.
I haven't reread the thread, but I believe it works with the ignition off until the battery would drain itself beyond recovery, then the engine kicks on. Besides, turning on your vehicle for it's power does not make it useless for camping. It isn't a rolling Goal Zero battery bank. However it is an objective upgrade in capability.
Hopefully there will be some method that doesn't jeopardize battery warranty. Huge untapped overland potential.
From the other thread, it was said that the 2400W inverter was the only power tap from the hybrid pack and that was only enabled with ignition set to accessory.
I agree with the 1.87kwh number being the published value. However, that's a lot of space in the rear being taken up for such a small battery pack. The 4xe in comparison has ~ 37kwh. Though it is a PIH and has a battery-only range of something like 25 miles.
Makes one wonder how long the battery assist feature can sustain? What is the use map like for the hybrid assist in the 250? Is it for peak demand only or does it actually supplement in normal drive cycles?
