24v alt testing??
VANCOUVER BC
Hey guys, will be seeing lots of rookie questins coming from me in the next few weeks. Am not getting 28v over the terminals when running, replaced both Batteries, still problem, not 12vstereo or anything like that in it, so Aternator...any suggestions on how I can test this preferable without taking it out and bench testing it? Also any ideas on what else may be the source of my worries, looking for some 24v cruiser expirience??
regards
J
It is easy to test them:
While the engine is running, apply full battery power to the field (F) terminal on the alternator by jumping across the B lug (battery and F terminal. Then read the voltage. You should get at least 28 V and the voltage will increase with engine speed. Don't do this too long or it will overcharge the battery.
If it fails this test, chances are the brushes are bad.
You can also test the diodes (rectifiers) with an ohm meter. Disconnect the B wire. Check the resistance from the B lug to the case, then reverse the leads and check again. There should be high resistance in one direction (1 meg ohm or more) and low resistance ( a few ohms) in the other direction.
Pin_Head's right, there's really no difference between 24 and 12 volt alternators except the outputs, and the tests are the same. That field voltage is usually supplied by the vehicle, variously coming from the ignition system or the voltage regulator, or in a way, both. The alternator won't do anything without voltage applied to the field so if when you do the B+ - field test described above the alternator begins to put out you would want to look somewhere besides the actual alternator for your problem.
If it doesn't begin to charge with field excitation, change it or have it repaired.
Hummm.... if any one can follow me here, facing the truck the left bat neg is grouded to the frame the pos leads to the neg of the right bat whose pos goes into the truck. Now the Alt has a wires that go to the tope of the engine...a set that go into the truck and a set that go to the regulator. In the diagrams I have found, the b termial wire goes to the battery...mine doen't..?? And the suggested test was to test between the b-lug and the negative bat terminal, right? Am I missing something. suggestions.
J
Chances are that it is wired correctly. The alternator White/blue stripe B+ wire doesn't connect directly to the battery; it connects to the chassis side of the fusible link that goes between the battery and the chassis. Just jump betwen the B lug and the F terminal of the alternator and measure the voltage from the B lug to the ground.
It does look like someone messed with it in a BJ40, but despite the birdsnest your important wires come from two marked terminals on the voltage regulator. You can pretty well ignore that capacitor as it's just there for RF (Radio Frequency interference)control, as well as simply leaving all that you see in place. You're only interested in finding out if the alternator works or not, right?
I'd just find the voltage regulator and apply 24 volts to it's 'F' terminal and listen to the alternator with the engine running. This can be done at the 'F' terminal on the alternator too but it could be harder to do. If the alternator is charging you should hear it hunker down. It's kinda' hard to describe the sound you want, but think of a refrigerator coming on; an electric motor starting; an air conditioner kicking in. If you hear such a sound by simply energizing the field circuit you'll be able to stop suspecting your alternator and look askew at the voltage regulator.
BTW, you can obtain your 24 volts using a jumper wire from your L/H FACING IN THE DIRECTION THE VEHICLE WOULD GO FORWARD (it's how I always think of it - sitting in the driver's seat) battery positive terminal, or from the starter below it.
As Pin_Head warned above, don't leave any test wire hooked up longer than necessary to find out what you want. There are other things in the circuits involved that may be damaged by this sort of testing.
A better avenue for you without any testing equipment would be to take the vehicle to someone/someplace that has the equipment needed to test your systems without putting them at risk.
Ah ha!! J.(gardiner)L. Its Steve here, welcome.
I thought it might be you. I couldn't tell without your bio & location filled out. (fast boats huh...... So, how fast CAN those boats go????)
I've got a manual for you, and we can go through it together.
I realized (after our last phone conversation) that your '82 was the first year of the 'Super-Glow' and not the manual glowplug pre-heat that my '81 has.
(the Superglow its a timer that applies a high and low voltage sequence to your glow-plugs depending on the the coolant temperature)
Your's is a tricky SOB to troubleshoot, but it's do-able with the Factory Service Manual (did you have any luck downloading it from Birfield.com?).
Don't spend too much money on parts before we talk, I'd hate for you to get hosed by the local parts store selling you the wrong stuff (or even Toyota charging you full price). I wish I'd had someone to guide me in those early days....:frown:
....Last exam done tomorrow at 1100. I'm hoping to move the truck back to my place as soon as I can.
Cheers,
Steve :beer:
