I have an 85 yota 4x4 with the 22re. My fuel injectors are not firing.
Ok, here's where I stand at this point.
The engine will try to fire with starting fluid.
I have 12v at #10 and #20 on the ecu.
E01 and E02 showing to be grounded.
12v from the resistor.
12v at the injector plug with key on.
Signal generator in the distributer ohm'ed ok and set gap to .010. (This is reading closed wether the signal rotor in on it or not. Should that be this way?)
Getting 1.09 v at IGT on the ecu while turning engine over.
Getting .75v at IGF on the ecu while turning engine over.
Getting continuity between ground and #10 & 20 on the ECU while turning engine over.
Getting continuity between injectors and #10 & 20 on the ECU with engine off.
Have 12v at NE on the ecu with key on.
I am getting fuel to the rail.
My wiring harness is grounded to the intake and have checked all grounds all ok.
Hooked up a niod light the the injector plug, and am getting no signal.
will this information help anyone figure this out?
