22re missing out
My 86 runner was running great then the other day started not wanting to idle now its missing out will not run with out pressing on gas. Smells like gas when running i did tune up plugs wires cap still same problem. will a injector stay on and cause this? Or computer I tryed reseting not sure if that works on toys.
unfortunately with the 22re it could be all sorts of things. you have to start a process of elimination.
Ok check the can blew it out. Cleared up for a sec. Is the can supost to be pulling vac from the bottom hose? If so were does the line go? If I plug the small vac line on the top of can runs fine????? Wtf I dont want to leave it like that . So replace can or?
