- Joined
- Jan 1, 2013
- Threads
- 17
- Messages
- 45
Ok, the skinny ...... I have a rough idle problem Im trying to hunt down on my 85 4runner. It has 210k on chassis and previous owner SAID it was rebuilt at 170k. Now with that out their I did a compression test this weekend and and here is what I got;1-->170 psi2-->150 psi3-->150 psi4-->155 psiNow the only thing that was odd was the number 1 cylinder pumped up smooth all the way to 170 then peaked. With the other 3 cylinders it took a few rotations to start pumping up then went to their pressures. I repaeted them two or three times to verify and thats what happened. Could my cam, valves be bad or does it sound like a valve adjustment? I dont hear any ticking at any rpm so I just over looked adjusting valves. and yes I already looked for obvious ; vacuum leaks, egr sticking, TPS out of adjustment, checked IAC for being dirty all are good. It pulls good through all the gears just idles rough. Plus I adjusted timing and played with the idle air screw. If I idle it up its better but still rough.
