22re+5speed+doubler
Shelton CT
i wanted to know what is the distance between the center of engine mount and rear drive shaft flange on the t-case of 22re+5speed+doubler with marlin crawler dual transfer case adapter. i want to move whole drivetrain back on my new buggy without reworking the rear 4link crossmember. i don't have the engine yet and would like to make sure that it would not hit the rear x member after i move it. thanks for the help.
that will hinge on the 5speed in question.
w56 and g52 are about the same length, but r150 and r151 are longer.
yes, center of engine mount to rear drive shaft flange. thanks.
I'm running a 22RE W56 and a clocked Marlin adapter, and I can measure it tomorrow if no one else chimes in. :cheers:
Center of engine mount to the rear flange correct?
Jerod, the ball's in your court, I think you, out of all of us, have the most direct experience with this particular field. :cheers:
PLFJ40, I think you may want your buggy's defroster looked at.
that's actually road salt all over the buggy.
