22r to 22re or 22re turbo
Montana
My buddy is looking into swapping out his 22r from his 84 pickup. He wants to swap in a 22re or 22re turbo. Are there any reasons that this swap wouldn't work (mounts, room etc.) ? Let me know if there are any good threads that cover this. Sorry if its allready been asked. TIA
Lee
Along with a 22RE, you will also need the ECU, harness, fuel tank with 50 psi pump, instrument cluster with VSS and MIL (check engine light), the EFI Cam, and the EFI Distributor. If you opt for the 22RET, then you need all of the above, plus you get to inherit one of the biggest heart aches Toyota ever produced ( yea, I know a few of you got 200-300 hundred thousand trouble-free miles out of a 22RET, but most of you didn't).
but technically both would fit and work?
Howdy! Yes, it will all fit just fine. It is the same engine in the same frame and body. 85 was the crossover year. They have both, but they differ from the head on up. John
Sounds like a lot of trouble to go through. Why's he looking to do it?
Ok dude...here goes
the difference, ala LC Engineering....
HEAD
20R.....80/81cc
81- 84 22R.....82/83cc
85-95....52/54cc
22RET......82/83cc
RET comp ratio is 7.5:1 has dish pistons (more than a 9.3:1 RE ;) )
The motor (RE Vs. RET) is the same X pistons and head cc + wiring nightmare for wha, 20 HP?
The wiring harness for RET is different so can read boost in the gauge cluster. (?) And possably other things the computer needs to monitor the turbo so you would need (as if an RET truck isn't rare...) an RET wiring harness.
PLEASE DO US ALL A FAVOR AND DO NOT ATTEMPT!
YOU NEED THE HYBRID 20/22 :bounce2::bounce::bounce2::bounce:
for now............................................
