Wanted 22r rocker arm assembly needed
Status
Not open for further replies.
under rock in Norfolk va
Im looking for a rocker arm assembly for my 22r motor which is 83.
Ive had no lick finding one, i snapped a rocker on number three exhaust.
Sucked driving home on three cylinders.
Have no luck finding locally
How much shipped to norfolk va. 23505. ?
Thanks for any help or point me in a direction to find one. Thanks. Any and all.
I am all the way over in Washington State. I'd have to look into shipping costs, but I have more than a couple rocker arm assemblies that will fit your motor.
I found a junk motor localy, pulled my vavle cover off and i broke another intake rocker? Cyl 3 firstand then cyl 2. I only drove 20 miles home after i found number 3 broken. What gives? I havent overheated in 4 years.
Is it safe to theow other rocker assembly in? Motor is stock with weber
In my first post i said cyl 3 exhaust. I was wrong. Both were intake rockers. Started her up and sounded s***ty. Something is loose. Leak down test or compression check or set vavles cold. ? Was trying to warm up to set vavles. Come to think of it, before all this when i cold started it would back fire through carb and not want to start and then start. I set timing mark to tdc and dizzy to number 1 and it all lined up. Before pulling rockers ??? What the hell, any suggestions would be appreciated. Thanks.
Status
