22r 2wd flywheel/clutch/transmission cover into a 4wd 22re
FOG TOWN->SF<-
Well the motor just blew in my 90 pickup and I am in the process of replacing my old 22re motor with a 86 22r that came of a 2wd.
I'm going to swap everything over oilpan, intake, exhaust, sensors....
But my question relates with the flywheel and clutch/transmission housing cover. The oil seal and the clutch are brand new in the 22r. I know that the clutch should:rolleyes: work. But will the flywheel be okay. By looking at it and counting the teeth on the flywheel looks to be the same as the 4wd. Can anyone chime in? are they interchangeable? and/or are they the same? How about the transmission cover. Same as the 4wd?
Don't really want to do unnecessary work if not needed.
Thanks
2wd and 4wd flywheels and clutches are the same. There is some difference in a 90 clutch and a 86 clutch, not sure if it's a major issue tho. Not sure about the cover.
