203 to split case linkage
here's the crux of the biscuit...I found a piece of 1x1" square section rod the length of the existing shifter pivot the OEM linkage pivots on, had a machinist drill a hole down the center (gun-drilled?) just larger than the OD of the pivot (left room for grease), then cut the square rod into three sections and put brass washers in between. each section gets a shift lever...only two installed so far. then, I took the same strap stock, drilled a bunch of holes in it, and made it just tall enough to end just below the cab floor. at the top I welded on some 1/2"-13 weld nuts so the shift levers could be easily removeable. since the levers at this point are strap, it's easy to bend them so they point at the hole in the cab floor, yet are very stiff in the fore-and-aft direction for shifting.
here's the two low-range shifters as seen inside the cab. they're machinery levers sourced from McMaster-Carr (as were the all-thread, heim joints and weld-nuts)...1/2-13 thread with removeable balls. this is an '85 FJ60 with an H55F, BTW. when I get around to adding the 4WD lever, I'll probably open up the hole in the cab floor...not absolutely necessary, but the existing hole is a bit small for three levers. I did a LOT of playing around to figure out which holes on the straps to use to get the distance the lever has to travel to jive with the distance the gearbox mechanism needs to travel, and then to adjust how long the all-thread needed to be cut to so I had some adjustment at the heims without being too long or too short. it turned out perfect...the shifters don't have high effort, and both travel about the length of the hole in the cab floor. the shifting is positive enough that I can split-shift the two low-range boxes if I can muster the concentration :rolleyes:
here's another shot looking up at the how the heims connect and the weld-nuts above that. and my bling blue weatherseal :flipoff2:
I used stainless for the fasteners, and as you can see I should have bought stainless all-thread :doh:
I think the 4WD lever will require more effort to engage, so might cause a problem. notice that the range boxes' all-thread is connected above the pivot...I might need to connect the 4WD link to strap welded BELOW the pivot to get the mechanical advantage (lever arm) needed.
this is really the only mechanical thing I've ever designed, and I like the way it turned out. one big advantage of doing it this way is that the entire linkage lives on the gearboxes, so nothing changes when the truck is twisted up except the shifter to cab floor orientation...no popping out of gear nonsense. TornadoAlley and Chef did a great job of helping me noodle out how I was going to accomplish this, and also getting my shizzle welded up!
:beer: :beer: :beer: for the boyz...
oh, yeah, I bought the 203 adapters and gearbox assembled from Charley Rupp at ChimneyCanyon4x4 in Rapid City, South Dakota...great guy, a big help. I also spent some time bugging Mark Whatley and Mudrak (Gary Kardum) about stuff involved in this project, since they also sell the 203 adapters...they provided a lot of help. Also, I pestered Jerry Nichols some...he's the guy who designed the adapters and partnered with AA to get them made and distributed, he was very willing to help, too. Also, Wagoner Machine in Haskell, OK does a 3.1:1 gearset for the NP203, if the stock 2:1 isn't enough for ya. with the H55F, NP203, splitcase and 3.73's, I'm at 82:1, which is enough for me so far :cool:
Steve
Steve
Steve, did you use the 3.1:1 gearset from Wagoneer Machine?? Do you know anyone that did? Any problems?? This is the first I've heard of it.
Thanks,
Man this thread has turned out great...I knew I would get some response but the pictures have been more thna I had ever planned on....Thanks guys...
brought back from the dead.......any new work being done on these set ups???
I am home with nothing to do but look at the internet and grab idaes for when I can get outside again...
Cool thanks for the pic, now can I ask one more favor?? Can you take a pic further back?? I want to see how you attached the clevis to the high low shifter...Thanks Tim
On a normal earlier splitcase I normally weld a tab 90degrees from the original orientation so a front to back pull will go from high-neutral-low. Actually finishing mine up and picked up some steel today to do just that tonight. The stock orientation for high-low is side to side. To twin stick it weld a tab onto the existing lever on the top of the tcase, get a smallish clevis or rod end and change the orientation to push pull from the front.
YEah, I was just reading that! Was also thinking a quick and easy way to get the 2wd and 4wd linkages hooked up tonight on my junk is to weld a small angle iron tab onto the front of the engagement rod, then attach a rod end to it. Easier than drilling out the hardened steel.
