So sold the fj as i was in need of a ute for my hunting trips due to the fj being so limited on space. Picked up a brandnew 2025 sr hilux. So far already installed arb frontier rank, stainless airbox and snorkel and slimline lithium battery setup have just ordered custom built fox shocks (2.5 factory fronts and 2.0 performance rears at custom lengths and valving), also have the sr5 headlight upgrades on order.
The front shocks are here, courtesy of accutune again
415mm compressed length and 595mm extended length and custom tuned. Gonna be a lot of parts swapped out to accommodate this length but will be sick when its finished
Front bar is on, went with the oem premium bar as was well priced, and there is absolutely no way they can blame it for any future radar issues that come up, it also isnt to bad looking
Tray is on, as is suspension but stilk needs some tweaking to work properly (clearance issues with sway bar and upper ball joint, will post sus photos in couple of weeks) for now heres the new tray
Another update, suspension is on and the long awaited 5mm aluminium bash plates are on. Suspension rides like a cloud up front, the back just needs some weight on it, still have some fine tuning and tweaking to make it all work flawlessly Skid plates look absolutely stunning (for now).
Suspension list so far
.Parabolic 600kg leafs
.Accutune Custom built 10 inch travel fox 2.0
.Accutune custom built fox 2.5 factory coil overs 6.3 inch travel (416mm compressed 595mm extended)
.Blackhawk uca
.Phatbars 30mm forged arm style diff drop
.2 inch extended brake lines all round
.party bump extended progressive bumpstops
going on soon will be accutune ride front bumpstops, washer reservoir relocation to properly mount shock reservoirs and offset uca bushes to try get just a rad more clearance between the balljoint housing and coil at fulldroop
Canopy is on, tray and canopy add about 120kg extra weight to what it weighed from factory with the tub, will post more pics as i start kitting out the inside
