2023 GX460 stuttering under load
East Coast
Had this vehicle since new, 17k on it now. Since new it shutters rapidly but faintly when under load. Example - going up a small incline at 50 mph and adding throttle and close to a downshift but not there yet. At first I thought it was just bumps in the road but it's happened enough that I've narrowed it down to when under increased throttle input on inclines close to a downshift.
Are there any OBDII data points I can look at to see what this might be?
do you feel the dash board vibrating as well? sounds like something loose in there? mine did that and i attributed it to using 87 gas. once i changed to 91, it went away for the most part.
why did i use 87, when gx calls die 91 you may ask. because all other toyota 4.6 use regular and i figured would be close enough. must be something with the tuning.
Dash does not seem to vibrate. I feel it in the seat. Filled up on 93 today because that's what was there and took half a bottle of pain killers to numb the 1.25 additional cost per gallon. Will report back.
Do you not run premium regularly as prescribed by Lexus? If not, you may want to add a bottle of octane boost too, so your entire fuel tank is at a higher octane. The "regular" stuff that was already in your tank mixed with the 93 octane you added is diluted and not 93 octane. Do an AI search (or similar) to find what would be the best/legit octane boost.
See if that works.
Also, what RPM's does it shuttering at? I wonder if your trans is not lugging in too high of a gear and should be down shifting sooner. How many miles on your rig and have you ever serviced your transmission?
Wife and I are heading out on a couple week road trip through Highway 49. Basically the route and towns where all the 1849 gold mining was going on in the Sierra's. Before going, tomorrow I'm getting my vehicle serviced AND my transmission too, since I'll be going up and down a lot of grades.
Thanks I'll check out the boosters.
17,000 miles on truck. Recently did a full driveway swap of the trans fluid. This stuttering/shuttering has been going on way before that.
Low octane isn’t going to cause a shutter.
IMO since you stated it’s been doing this since new I would take it to the dealer and have them drive it. Maybe compare it to a similar vehicle.
Didn't see your signature that your rig was so new. Absolutely agree with @aztoytec, take it to your dealer, especially if you can replicate the issues with a tech in the car.
