2021 Fuse Locations
How do I access the passenger side fuse box on a 2021 200 series? I lost towing backup lights and want to start with checking that fuse. Thanks in advance!!!
You’re on the right track, there’s a 7.5A Tow Backup fuse in that junction block. Remove the black panel under the glove box (the one just above passenger’s feet), 2 screws and 3 tabs to unclip it. Junction block/fuses should be on the right side of the glove box.
You do not have to remove the glove box to get to the fuse box. But getting to box and the breakers isn't exactly easy. Standing on one's head helps.
The black panel under the glove box has 2 tabs at the rear of the panel which release it. You'll want to disconnect the wire that powers the light at the footwell by pressing the center tab on the white wire connector clip. The fuse box is on the passenger side against the outer edge of the body.
Yellow arrows point to the release tabs. Just push them and the panel falls down. It actually comes off TOO easily, IMHO.
Thanks Much! We are in Illinois now, when we stop tonight we will check. Again thanks for sharing your knowledge.
