2021 / 2020 Lexus GX460 Lug Nut Size
NY | NJ | PA
Hi All... I tried searching but couldn't get any results on here. I'm trying to purchase lug nuts for aftermarket wheels for a 2021 GX460 and I keep getting different sizes via google, can anyone kindly confirm if the 2020+ GX460 uses 12 x 1.50 or 14 x 1.50 lug nuts? About six dealerships I called were of course no help.
Any and every help would be very much appreciated. Thanks in advance!
One thing to consider with lug nuts, some wheels require the nuts to be chamfered, meaning they are not flat on the bottom, but have an angle so when you're tightening your lugs they will center in the hole of the wheel.
So, in short, check to see what type of lug nuts you need for your wheels while looking for thread size.
But from a quick Google search, I've found: Chrome Cone Seat Acorn Bulge Closed End Lug Nut by Febi®. Thread Size: M12 x 1.5. Hex Size: 19mm.
If you have a set of caliper's (example:
Amazon product ASIN B07X8JQ8L5
Just measure the diameter of the nut in metric. It will either measure 12mm or 14mm, that will for sure tell you. Note: if you measure, it WILL NOT BE EXACTLY 12mm or 14mm. IT WILL BE A LITTLE OFF. The 1.5 is just the thread pitch.
Personally I'd go with the 12mm size and for the cost, if you're wrong, you're out 20 or 30 dollars.
Thanks @r2m - I very much appreciate your input!
The wheels are GramLights 57Trans-X Rev Limit Editions and I was planning to use Rays lug nuts as I'm getting a great deal on them anyway because there was a mix up with getting my wheels shipped and vendor is looking to make things right with me... just so I don't change my mind.
The 460 is currently being ceramic coated for next 4 days so it's not here with me but I'll definitely give the caliper a shot. I had the Gorilla Automotive 21134ETBC Black 12mm x 1.50 lugs on my previous GX470 which I sold with my wheel set up.
Thanks again for your help.
Did you ever sort this out? I'm looking at Gram Lights as well.
edit: woah old thread revive
