2017 A/C Servo Motor Fail
NC
Had issue with A/C not coming on until about 30 seconds after starting engine. Did some checking and found that the recir flap behind glove box door was not functioning correctly. It also would not work when pressing the recir button. Took it into dealership, they found DTC B1448 face servo motor circuit (passenger side) failed, and recir door on blower assembly broken. They said there was a TSB but it had expired. They recommended to replace the entire A/C unit along with blower assembly.
Here is the kicker: cost to do the entire replacement is $10,688.00. I'm obviously going to go get 2nd/3rd/4th opinion but can't believe that the entire system has to be replaced. They said that since they were in there (have to remove entire dash) and due to mileage of vehicle (196k miles) they recommended.
Asking if anyone has had similar issue and did you replace entire system. I've searched but not much to go on unless I missed something.
The Car Care Nut just did a video on this, it was a nightmare repair. Whole dash gotta come out, search on youtube and watch that video
First of all, and before you do anything else, get the easy fix for the broken door and install it. The filter door mechanism is often broken by poorly trained maintenance persons and it’s well documented on this forum.
It’s very likely that after you install this, your HVAC system will start working correctly, though you may need to disconnect the battery for a few minutes to reset error codes. A faulty functioning cabin filter door mechanism can play havoc with the HVAC, causing odd symptoms.
And if want lots of reading on this, here’s one long thread.
Thanks. I will look into that.
So I just picked up vehicle from dealership and got back home. I looked at the recir door behind glove box and looks like the tech fixed it. It opens and closes normally when I hit the recir button on dash; tried it a number of times. However, still have to wait ~30 sec to get HVAC to come on.
Wondering now if I disconnect battery for a few minutes it might reset codes? Might give that a try...
So disconnected the battery for a few minutes and reconnected. Still get 48 code for passenger servo motor fail. After watching CCN video and seeing what he had to go thru seems to make sense to replace entire HVAC. But for now will just live with delay as I’m not sure I want my vehicle and wallet to have to go thru that…
There are other things to try before flattening your wallet. The servos (motors) in the HVAC can be re-initialized either at the dealer or by you using Techstream. Since the technical service bulletin on the known servo issue has “expired” (not sure what that means), it doesn’t mean the procedures can’t be used. Also, I think there is a HVAC reset procedure using the center screen for input. Search on Mud (using Google) for 200 Land Cruiser HVAC reset ih8mud.
Yes. Agreed.
The TSB tells you to try the reprogram first.
I asked the dealer to do it and had them reprogram my AC ECU just a few weeks ago. It’s not expired. Maybe the free repairs are but you can still pay to have them do it.
Sounds good. Thanks for info.
Any update on this?
I recently picked up a 2016 that just had a new battery put in. I wonder if this is the genesis of my similar issues. I replaced the servo arm on the glove box, as my recirc wasn't working.
Currently, my A/C is resetting to 75°F overnight and the fan speed would be off/very low, when the prior setting had been "LO" with fan speed on high. The rear air is throwing codes B1447,B1449,B1488, and B1497 and not blowing cold air or switching from roof to feet. I'm hoping that the Lauch/Techstream device will recalibrate the rear servos and get everything working again. It just seems unlikely that all the rear servos would be dead. Fingers crossed.
Any update on this?
if your battery was recently replaced, i would 100% try the servo reset first before going down the TSB path.
If you guys have Techstream, go to the active tests and check each servo's actual pulse value vs. the target value. Do this with the active test, and then do it via the HVAC controls in the vehicle.
Update: I took it to another dealership and they gave me a much lower cost. I ordered the parts and was waiting for them to come in. Well, last week I get in the vehicle, started it up and everything is working fine. No codes, no AC issues. I’m not sure what happened but maybe the AC motor started working again? In any event I have the parts but going to hold off on the installation.
Update: I cleared the codes that all pertain to the rear servos and rear damper door. I performed the servo recalibration through the Launch Creader. No luck. Codes came back and the rear defaults to ceiling vents at 75°. After giving this some thought, I would not be surprised if the previous owner rigged a fix this way in lieu of replacing all the servos. In reality, it’s not that inconvenient, although still annoying.
That’s probably just where the servo is being parked by the AC amplifier.
Some of the servos are actually controlled via another servo. So, the servo that is not operating properly may not actually be the servo that has failed.
This can make it is super frustrating to diagnose. And, if you’re bold enough to shove a new servo in there and just assume your diagnosis was right without testing the repair and then button everything up, it can lead to repeating that entire GD job for free—ask me how I know. 😑
Soooooo if you are able to see a data list— clear the codes and then try to operate each servo via your AC controls. Find the one servo (it could be more than one) that have an actual pulse value that differs from the target pulse value. Note the names, report back with your findings.
That is wayyyyy too complicated for me. Lol I just purchased a 2017 LX 570 this past week from Carmax and I noticed this problem and thank God I found this site today. I have a 30 day warranty, so I have to get this figured out quick. When i found the thread on the jammed recirc door I was like, yea dummies at Carmax replaced the filter and broke it. Nope,,,that door is working just fine. My filter does have a sticker on it that says to set on recirc first unlike the older ones
After all this research I have a pdf summary for your service advisor if anyone is interested. Can be used obviously for any LC200 series. It is also a problem almost their whole lineup for 2016-2017
So I told Carmax the codes coming up on the diagnostics via controls. (48) They said everything was working fine 45 degrees cold 135 hot. I said that is not the issue, now they want to take the dash apart. I wonder if they have the scanner to reprogram servos. They didn't mention they did anything like that. Anyway, they extended the return period until after they tear into the dash. We shall see.
I suggest making sure Carmax tries the servo reprogram first. If it was mine, I would do almost anything before letting anyone tear into the dash.
