For Sale 2016 TurtleBack Trailer Demo
Status
Not open for further replies.
Our TurtleBack Trailer demo is for sale. This trailer is loaded to the max with all the options. It is in like new condition. We have used it for a handful of shows and events. The trailer comes with the full manufacturers warranty, and can be financed just like our new trailers. Take advantage of $3,000 savings. Located in Graham, TX.
Standard Equipment:
Full Steel Trailer 2x3 Perimeter Box Frame, 3500# stub UCF Flexride Rubber Torsion axles 2750# Springs, 10" Electric Brakes, 16" Steel Wheels, 265/75-R16 BFG KO2 BFG Tires, Forward and Aft Receiver Hitch on Frame, Bedliner Coated Chassis, 0.060" White Aluminum Skin, 2 Side and 1 Rear Compartment Doors w/ Matching Keys, LED Lighting, 11# Propane Tank with Stainless Steel Bracket, Deka Group 24 AGM Marine Battery in Box with Blue Sea Fused Terminal Block, Blue Sea Systems® Marine Grade Electrical Components, 4 Rail Cargo Bar Roof Rack, 2000# Swing Away Tongue Jack with Foot, Safety Chains, 7 Way Flat Trailer Plug Wired to: Running, Brake, Turn Charge Line & Trailer Brakes, Interior Lighting in Cargo Area and Kitchen, 42 Gallon Fresh Water Tank Food Grade, BPA Free Construction, Flowjet 12v Demand Water Pump, Atwood 6 Gallon DSI Water Heater, Exterior Shower, Baltic Birch Pantry Drawer in Kitchen Area, Baltic Birch Slide Out Kitchen with 2 Drawers, 2 Burner Wedgewood Stainless Steel Stove with Stainless Cover by Atwood, Stainless Steel Sink with Hot & Cold Faucet.
Tailgate - Includes 18”x36” brushed stainless steel fold down table, spare tire mount, spare idler hub with greased bearings, Turtleback Trailers Rotopax dual mount.
48"x32" Nose Box, 45" Side Box, 25" Side Box Our Storage Box Set are constructed in house using CNC Laser cut aluminum. Then they are CNC bent to insure the perfect fit. Our welder TIG welds them together then they are powder coated in and out. We finish the assembly with 1/16 stainless rope to hold the doors at a 90 degree for additional table space. We line the door with Baltic Birch inserts and seal the doors with 3/8" rubber bulb seal that is connected with a steal re-enforced pinch welt. We use polished stainless like keyed latches.
Includes Blue Sea 1 Battery Disconnect, Blue Sea 6 Circuit Fuse Block, 6 Amp Marine Battery 2 Bank Charger (Shore Power), 10 Amp Solar controller with Voltage Meter.
-Options/Upgrades
-Custom Color
-Max Coupler
-Picnic Table Mount
-Spare Tire and Wheel
-Receiver Lock Plug
-UCF Spare Spindle
-Battery Electrical System Upgrade
-90 Watt rollable Solar Panel
-Additional Charge Ports
-2000W Pure Sine Inverter Package
-Additional Grill Tank
-Partner Steel Stove
-18" Partner Steel Griddle
-2-2 Gallon RotoPax Fuel Cans
-RotoPax Deluxe Mounts
-23Zero Byron Roof Top Tent
-Foxwing 270 Degree Awning
-2-Foxwing Tapered Awning Extensions
-Telescoping Awning Slide
Base Trailer Price $17,999.00
Options Included $ 7,487.95
Total MSRP: $ 25,486.95
Demo Sale Price $22,500.00
Lots of pictures here: CB Adventure Supply, LLC - Photos | Facebook
Super nice trailer! I'm a little confused as to the foxwing awning - seems mighty close to the ground to use an awning....
It's on a telescoping mount. You can raise it however high you want when in use. Then it slides back down for transit.
I don't seem to have a good picture of the awning deployed, but these give you the idea. For reference my wife is 5'8"
Status
