2016+ Rear Screen Removal
I just bought a 16 and sadly when I turned the passenger side on for the first time the screen was broke. If anyone takes theirs off and does not want it I woud buy it.
Thanks for the step by step instructions on this thread. I don’t know what I’m doing wrong, but this job was a bear. Removing the screens was easy enough, but I could not get the bracket holes to line up with the holes in the cover, no matter how much I adjusted them up, down or sideways…the brackets were wider than the holes in the covers. The short screws didn’t make it any easier to get them threaded either.
I finally got them on after drilling the outer edge of the cover holes slightly bigger. On the drivers side I also had to add washers behind the brackets to push them out, allowing for the short screws to reach…this worked, but there is a slight gap between the cover and the seat as a result of the washers. I may remove it and drill both holes in the cover wider in order to try to get rid of the washers, so the cover fits tighter to the leather…but it looks ok for now.
I figure I must be doing something stupid since no one seems to have had the problems that I did. But I can’t figure out what I was doing wrong.
