Also noticed that when I would turn truck to the left the sound dissipates (less pressure on right side).
Actually ... when turning to the left, there is MORE pressure (aka load) on the right side.
HTH
Could be a bad bearing
Symptoms of a Worn Wheel Hub Bearing | KnowYourParts
Humming, rumbling or growling.
These noises are normally associated with tire, electrical or drivetrain components. If bearing-related, the noise or vibration is present when driving in a straight line, but intensifies when turning the steering wheel slightly to the left or right. Typically, the side opposite the rumbling is the defective side.
sBrought the truck back to NTB this morning. They drove it and said that they did not notice anything out of the ordinary, that it was not a balancing issue because there was no vibration in the vehicle, and said that maybe the whining was a wheel bearing issue and suggested I take the truck to Toyota. They clearly did not want to deal with me. When driving home last evening (about 50 miles) I definitely noticed that it takes the tires coming up to temperature for the sound to become overwhelming. Also noticed that when I would turn truck to the left the sound dissipates (less pressure on right side). When turning to the right the sound is the same, maybe marginally worse. NTB has simply said the tires were properly installed, appear to be properly balanced, and that if i'm dissatisfied I should take it up with Tread Depot. I called Tread Depot, and they said that unless there is a mfgr defect they won't take them back. These tires did not come with their 30-day test drive guaranty. Not sure where I go from here. I may try Toyota dealership or a real tire shop that is willing to take the time to work through this with me. If what I'm hearing is just the noise of the tires then I'll have to decide whether to live with it or put my old BFGs back on, sell the ATWs on craigslist and start all over.
exactly my situation. I want the best of both worlds, know that I won't get perfection, but I am trying. My LC is my primary vehicle so I commute in it at least 2-3 times a week, all highway miles and often as much as 100 miles per day RT. In other words, a lot of highway miles. On the other extreme have a fishing/hunting camp 5 hours north of me in Maine, 10 miles down a gated dirt road and very close to off the grid. I run logging and skit paths frequently for bird hunting and fly fishing and those roads in winter and early/mid spring require much more than a strictly on-road tire. I love the extra 1 1/2 inches of clearance with the 275 70 r18s (i could have used that little bit of extra clearance several times earlier this fall) and I can tell that the ATWs will be great in snow, dirt and mud. The truck looks great with them, and if I was never going to drive it over 50 on the asphalt I wouldn't be complaining one bit. But when my kids tell me they can hear the whining through their headphones and its tough to have a conversation on the highway, I need better options.
As stated earlier I have these tires, and while they do hum, or whine a little it is by no means a conversation stopper in the vehicle. I've had other AT tires, some quieter, some not, in your case I would contact Cooper directly. There are a couple of other members in the 200 section that have experience with the tire also, maybe they could chime in. Otherwise there are mud members in other sections running this tire, expand your audience.
BTW, I don't buy a wheel bearing on such a low mile LC. These are not that kind of vehicle, unless something out of the ordinary happened.
Good luck.
Good luck.
