2012 LC200 no cameras working
South Australia
Hey,
Recently all cameras on our 2012 LC200 stopped working. Whether reversing, parking, coming to a stop at lights none work they just flicker black. Just wondering if anyone he experienced this or knew where the common point was for all 4 cameras terminated? I couldn’t see a fuse for all cameras either.
Cheers,
Ash
Hey,
Cheers,
Ash
Check the gray connector on the parking assist ecu. It's located above the plastic panel on the passenger side footwell. It's mounted horizontally right below the glove box. Aluminum case with the gray connector towards the center console. I had to reseat mine for that exact symptom on my '14.
Ah thanks. Tried it but no luck still has the same symptom. ECU could be cooked?
Did you ever find resolution here?
I have the same issue in my 16’. Dealer wants to sell a new parking assist ECU. $1400 part plus $1100 to install and program the cameras. I understand the cost of the part but the rest is excessive. I believe the install was $250 of the $1100.
I have the same issue. All cameras are suddenly inoperable. When I shift to reverse, I can see the vehicle image but no cameras. Local Toyota Dealer ran diagnostics and didn’t find and breaker or wiring issues and recommended I replace the ECU - $1200 for the part and $400 for labor. Anyone find a resolution for this?
