200K Re-fresh
Central Florida
So my 80 just crossed 200k two days ago. It's burning some oil but has really good compression. In the next two weeks i'm going to give CDan a call and order all the things i think i will need to get the job done. Below is what i plan to order. I need to know if there is anything you guys think i have not included on my list. The head is going to the machine shop for a complete re-fresh.
Thanks in advance for your advice.
Headgasket kit
new Head bolts
valve cover seal
All the hoses /PHH Silicone Pesky Heater Hose
Timming chain with new seal and tensioner
Timming cover gasket
Water pump/thermostat
All new belts
Fan clutch/maybe
Front Crank seal
Spark plugs
Spark plug wire set
Rotor button
Distributor cap
Spark plug gasket
Throttle body gasket
Fuel Injector grommit/orings/gasket/seal
Starter contacts
New vacumm hose's
Fuel injectors cleaned
Re-insulate wiring harness PHH on firewall
PS Hoses
Seal for PS Pump
Alt brushes
O2 Sensor conduit and O2 sensors
Fuel filter Mod
cdan will tell you but, you are also gonna need
throttle body gasket
why not do spark plugs, wires, etc - unless recently done...
spark plug gaskets??
depending on certain factors you may wanna consider some new vacume hoses....i replaced mine and my lc quit throwing the p401 code...runs alot better too..
You will probably not need new head bolts and should put the money elsewhere.
You can spec. the head bolts with a mic.--the FSM has the correct tolerances.
Your list looks pretty good. I would also add have your injectors cleaned and tuned by a professional and reinstall with the new rubber grommets/orings/gaskets that come in the valve grind kit.
Good luck.
-o-
Might as well put new contacts in the starter and replace the brush in the alternator. Five minute jobs when you have everything off. I would also redo the insulation for the engine wiring harness by the firewall (close to the PHH). It gets pretty brittle after 10+ years.
If you're going to be in that deep you'd better look closely at the PS hoses (HP & LP) and the pump. The HP hose isn't cheap but relative to your current list another $170 is nothing. Get a PS pump seal kit and overhaul it while you have good access. Don't forget your alternator either, brushes at a minimum but having a shop look it over would be a good idea.
Something I haven't read very much around here is the O2 sensor wiring that goes over the bell housing. On my '94 the plastic conduit was very brittle and melted in multiple locations. Yours may also need looking at and what better time than while the head is off.
Forget the head bolts. Spend elsewhere, like get a few exhaust manifold studs and bolt as some will prove stubborn and get chewed. Also, perhaps O2 sensors? I'd do the fuel filter mod (cut one hole on one end so it's a slot that is easily removed and do the new one preinstall as well.)
Throttle cable catchy? Replace that, too. Others got my suggestions already.
DougM
This is a slippery slope, but, hey, you asked...
All seals for anything intake/vacuum related since you will split the halves. Get an ICV o-ring. Get a new PCV grommet. New vacuum hoses for the brake booster.
Also, I tend to think of the EGR system parts as having a limited life so when I took my intake apart, I just replaced the VSV (it's the easiest time to do it) and the EGR valve and the vacuum modulator too. If you want to go way overboard, do the EGR temp sensor too. In my mind, they have done their duty and need to be replaced. Clean the heck out of all the vacuum ports while the intake is apart. After all this, you will avoid any EGR CEL's for a long, long time. But, maybe your EGR system has had various bits replaced already.
Also, check your valve clearances.
Distributor o-ring
That's all I can think of for now. But still thinking.
FYI, I love the project, but not sure you really should proactively replace the HG, but that's just me. My rig has 197k on the clock and the HG is fine. Mine uses some oil, but I don't attribute that to the HG. It has solid compression and no other indications of HG failure.
How much oil are you using? Is it really enough to indicate you need to pull the head ?
R.
The valve seals are gone she is burining at least a two quarts between oil chages, so i figure since the head is going to the machine shop i should go ahead and take care of the gasket and everything else while i'm in there. This is my 3rd cruiser and i like trouble free cars. I did all the preventive maintenance on my 2F and 3FE trucks and im doing this one bacause i'm planning a family vacation that will require lots of driving so i want to make sure the old girl does not leave me and the family on the side of the road.
The vacumm lines will be ordered...
WOW! U got a whole load of work ahead of you!
