- Joined
- May 19, 2008
- Threads
- 61
- Messages
- 368
Seeking some wiring help.
I purchased this 2008 200LC in Nov. This week I noticed my rear taillights were flickering a little and then they went out completely.
I cannot or have not yet found the ARB rear bumper installation instructions and wiring diagram.
The ARB bumper came with the vehicle when I purchased it.
Diagnosis: I've burned out three 15 amp fuses for the DS fuse panel trying to trace the problem. They don't blow immediately but after a few seconds they will blow when the car lights come on as best I can tell.
All other lights work. on the vehicle i have turn, brake, and backup lights.
As for the ARB bumper both signals work, however; only the left (DS) tail brake light works. The PS ARB brake light doesn't work.
I have zero rear running lights on the vehicle.
I can only conclude that it is a faulty ground wire somewhere. I tore into what I could and here are my questions:
1) What is the brown wire for showing in the picture? I don't see anyplace where it would go to.
2) Where could other ground wires be for the car and ARB bumper aside from behind the inner fender cargo area where they wired the ARB lights into?
3) The license plate mount and light was corroded and the bulb was blown so I removed. I doubt this would cause the car tail lights not to work since this problem happened afterwards.
4) Why am I missing so many AC type fuses from under the hood fuse box? Is that because I don't or may not have AC seats?
Any next steps you can suggest or help would be appreciated.
Thanks, Tim
Thanks, Tim
