2008 LC stuck in 4lo
Portland, OR
Hi,
My LC seems to be stuck in 4LO and the caution triangle is solid yellow and the the check VSC and PCS lights are on. Help any info or tricks to try?
thanks
Turn truck off. Restart. Does that help?
Also seems the 4wd turn shift knob is stripped out. Anybody know where to find one of these?
I got my LC back today with a hefty bill. $979 to fix the 4wd issue and a new shifter knob. The 4wd ECU that is behind the glove box is the fault. I normally wouldn't take it to the dealer for the repair but it wasn't very drivable in 4lo. So hopefully this can help someone in the future. The ECU part was $500 so I suppose you could do it yourself or find a good mechanic shop that is much cheaper then the stealership.
Will you be willing to share your work invoice once complete?
Did they indicate what may have caused the ECU to fault?
